Categories General
Created on May 2, 2024
Allow PI Web API Admin Utility to run silently
We use the command following command to run the PI Web API Admin Utility silently in order to automate SSL certificate updates:
OSIsoft.REST.Admin.exe --f=C:\temp\InstallationConfig.json --suppressUI=0 --verbose
If the admin utility crashes, this raises errors in our automation scripts. Please allow the utility to run silently and better handle crashes.
  • Tyler Engelhardt
    May 13, 2024
    @OP, I recommend using a configuration management framework, such as Ansible, to manage SSL certificates. I would not be running the utility the way you are. I've used Ansible to update the SSL certificates for both Vision & the API without issue.
