Product PI to CONNECT
Categories General
Created on Aug 14, 2025
Adding PI to CONNECT Transfer replication behaviour based on Edit Mode Search
Problem: Currently, each asset and stream from the PI System must be added individually to the PI to CONNECT Transfer. If an organisation wants to replicate all assets in a specific category or under a root element of the PI Asset Hierarchy, every change, addition or deletion in that category or root element also has to be added manually to the transfer. This limits automation and reduces the usability of CONNECT Data Services.
Needed feature: The Edit Mode Search in PI to CONNECT Transfer should be saved, and changes in the underlying assets should be replicated automatically.
Value: This would reduce manual configuration and save time. It would also allow new assets to be brought into use cases more quickly. In many cases, using CONNECT Data Services is only practical with this feature.
We would like to hear what other CONNECT Data Services users think and would welcome any updates on this issue. Thank you for considering this feature request.
