Status Completed
Categories General
Created on Aug 16, 2022
Enable the use of gMSA for PI Adapters running on Windows
In our environment, we plan to deploy PI Adapters on Windows Server class OS. We are in a strict minimum privileges environment hence we only make use of gMSA on all PI services. We do not want to make use of a domain service account where the password is known (by a few) and can be impersonated. PI Adapters should be enabled to make use of such gMSA type of account to run the service in a secure manner.
  • Admin
    Jiyeon Hwang
    May 26, 2023
    Thank you for your input. We have implemented this feature in the recent release of AVEVA Adapter for OPC UA (1.4.0.196) and AVEVA Adapter for MQTT (1.3.0.103), where you can now use Kerberos authentication. This is related to the following idea: https://pisystem.feedback.aveva.com/ideas/PIADAPTERS-I-35. We will be rolling this out to the rest of the AVEVA Adapters with the next set of releases.
  • Gabriel Verreault
    Aug 16, 2022
    gMSA's can be used to run the PI Adapter service. That being said, if using PI Web API as an endpoint, the only supported authentication method is basic and would require entering credentials of user / service account with the required access on the destination AF/PIDA.
