Created by Markus Rombach
Created on Mar 3, 2026
PI Adapters should handle good NULL Values like PI Connectors and submit to the archive
A PI Connector reading a Null value in good quality send it to the Archive
A PI Adapter skip the value, this gives in the archive a wrong picture.
please enable the PI Adapter to submit also Null values with good quality to the archive like PI Connectors do. (permanent or configurable)
  • Moshe Sabag
    Oct 29, 2026
    When the source (OPCUA server) is shut down, the data points in PI just go stale and quality remains good when using the PI OPC UA Adapter as a client. This creates a misleading situation for the users which is very risky since the interface does not clearly reflect the source objects quality.
  • ChrisMcKee
    Mar 11, 2026
    The current behavior causes trends in PI Vision to freeze at the last good value rather than showing the value has failed or when into error. It is extremely misleading
    It would be better to try to continue polling the null value even if it's to output the stream data via Web API as Bad, Error, or Questionable to the PI Data Archive.
