Adding my support for this request and flagging it as a high-priority data integrity gap.
Because the Adapter hardcodes CleanSession = true for the generic MQTT data source, any message published to the broker while the Adapter is disconnected (network interruption, Adapter restart, upgrade, or failover) is permanently lost. On reconnect, the broker has no session state to resume, so no queued QoS 1/2 messages are delivered and no subscriptions are restored. In practice this creates silent gaps in the PI historian that cannot be backfilled from the source.
This matters most for sites that depend on continuous, complete data collection, such as regulated manufacturing and process monitoring, where missing data can affect trending, analytics, and process/quality review. Planned maintenance windows and routine restarts are enough to trigger the loss, so it is not limited to rare failure scenarios.
Requested change: expose Clean Session (persistent vs. clean) as a user-configurable parameter on the generic data source, along with a stable, configurable Client ID (required for the broker to associate the client with its persistent session). Defaulting to the current behavior (clean = true) would keep this backward compatible, while allowing sites with session-persistent brokers to achieve true QoS 1/2 delivery and backfill after a disconnect. The underlying MQTT client library already supports this setting, so the change should be small relative to the resilience benefit.
