Categories General
Created on Apr 23, 2026
UOM lost on restart & missing UOM definition at data collection level
Description
When using the ModbusTCP adapter (seems other Adapters impacted):
  • Data is ingested into CDS as a stream
  • A Unit of Measure (UOM) can be manually assigned to the stream in CDS or EDS.
  • But on adapter restart, the UOM is automatically removed
This behavior is reproducible, has no workaround, and should be considered a bug. Adapter restarts should not remove user-defined metadata.
Requested Improvements
  1. Bug fix
    • UOM assigned to a CDS stream must not be removed when the adapter restarts.
  2. Functional enhancement
    • Allow defining the UOM directly at Data Selection level, e.g. via a unitOfMeasureId parameter alongside conversionFactor and conversionOffset.
registerOffset": 4000,
dataTypeCode": 20,
"conversionFactor": 10,
"conversionOffset": 0,
"unitOfMeasureId": "degree Celsius"
Functional Rationale
From an engineering and operational standpoint, this approach is more consistent and intuitive:
  • The engineer defining the Modbus register mapping:
    • Knows the physical meaning of the data
    • Already defines conversionFactor and conversionOffset
  • The unit is an integral part of the signal definition, just like scaling and offset
Defining the UOM as close as possible to the data source ensures:
  • Clear expectations on the adapter output
  • Better data quality and consistency in CDS
  • Reduced risk of human error and post-processing corrections
