Status Evaluating
Created by Jonathan Pegg
Created on Aug 3, 2026
Enable direct "in-grid editing" (and per-row dropdowns) in the configuration utility's Data Selection table to avoid export/edit/import for small changes.
As a admin, I want to edit Data Selection values directly in the table so that I can make a few quick changes without exporting to CSV/JSON and re-importing and appending or replacing.
It would be helpful if Data Selection grid supports editable cells for appropriate columns (e.g.,write directly to the cells like for Custom Stream ID or if several Schedules are defined, then in the Schedule column there should be a drop-down menu in each row to assign the selected schedule. Of course for bulk edits better to process CSV in MS Excel, but for a few edits, the GUI would be perfect.
Support basic bulk actions in the UI (optional but helpful): multi-select + apply schedule, copy/paste. Keep import/export for true bulk edits (Excel), but make the UI the best path for “a few edits”.
    Aug 25, 2026
    This enhancement is being evaluated for a future release. Please continue to upvote and/or provide any additional information relevant to how you work with Adapters and the configuration experience and workflow with the configuration utility. If and when this enhancement is prioritised, we will updade the status to "Planned" and "In Development". Once "In Development" we will provide an estimated delivery.
