Created by Kenneth Barber
Created on Aug 5, 2026
By default, the "Validate Endpoint Certificate" check box should be checked
According to the documentation of any AVEVA Adapter, the default value of the "validateEndpointCertificate" parameter is "true", which is good from a security standpoint. However, in the AVEVA Adapter Configuration Utility, the "Validate Endpoint Certificate" check box, which corresponds to this parameter, is not checked by default. Please check this check box by default for all cases of the "Validate Endpoint Certificate" check box: data endpoints, health endpoints, failover, etc.
Also, I recommend giving some visual indication whenever the user uses a suboptimal value for a parameter, which includes but is not limited to "Validate Endpoint Certificate". This could be something like ⚠️.
Lastly, check the other parameters, especially the security-related ones, to see if the default value in the AVEVA Adapter Configuration Utility does not match the default value when configuring the AVEVA Adapter without the AVEVA Adapter Configuration Utility.
