Created by Kenneth Barber
Created on Aug 8, 2026
Use proper names instead of programming naming conventions (e.g. "RDBMS", not "Rdbms")
From the "Configuration" home page, if I click on an AVEVA Adapter instance and then click on the "Configure Adapter" button, then, in the page that appears, I can see the name of the AVEVA Adapter in the top left corner. However, this name is written using a convention that is more suitable in programming: camel case, even for acronyms, and no spaces. For example, we have "Adapter: Rdbms" and "Adapter: StructuredDataFiles". This takes away from the polish of what is supposed to be a user-friendly program to configure AVEVA Adapters.
Please write the full name of the AVEVA Adapter (e.g. AVEVA Adapter For RDBMS) or, at the very least, write the adapter-specific part of the AVEVA Adapter name as it appears in the product name (e.g. Adapter: RDBMS).
Along the same lines, please use "ID" instead of "Id" (there are many cases all throughout the AVEVA Adapter Configuration Utility). AVEVA already deviated from the parameter name by capitalizing the 1st letter of the 1st word and by adding spaces between words, so you might as well write "ID" correctly for the full user-friendly experience.
Similarly, any acronym should be written in all capital letters (e.g. UTC, XML, JSON, CSV) instead of the "programmer" format of having only the 1st letter capitalized (e.g. Utc, Xml, Json, Csv).
