Status Completed
Created on Aug 16, 2022
PI Adapter for OPC UA data filtering based on OPC status codes
Currently, the PI Adapter for OPC UA sends good quality data to the configured data endpoint with no way to filter on different good quality statuses. There are several OPC status codes that fall under the Good Quality Data classification. When the status code changes from "Good" to "Good_Overload" because they fall under the OPC Good Quality Data classification, both are being sent to the configured data endpoint. User would like to have the option to filter good quality data. For example, send only data with "Good" status code to the endpoint and filter out "Good_Overload" data.
    Aug 16, 2022
    Thank you for your input. This feature is handled with the latest version of PI Adapter for OPC UA (1.2.0.136) in the case where you send data to OCS. PI Web API handles only "Good" data (ie. no distinction between other "Good" data types). Could you elaborate further on this use case?
  • Laura Morris
    Aug 30, 2025
    Is the being added to other OMF endpoint options, not just OCS/cloud? What if sending to on prem PI System?
