Created by Hans-Otto Weinhold
Created on Sep 28, 2023
If data contains asset information, this data shall be written to asset related streams
Challenge:
We have (CSV) data files which come from Laboratory or other measuring equipment where the data lines contain information on which asset the measurement was taken from. In our particular use case, we read sample data from lab analyzer which performs analysis on product quality for a specific skid/bioreactor. The data shall be split up to collect the data for each individual asset. Right now, the PI Adapter for SDF can't be configured to use information from the data to let it be split up into asset specific streams. To process the data properly, we currently use a Python script which does the processing of the data and sends it into a complex stream for each particular related asset.
Solution:
Allow configuration for the PI Adapter for SDF to consume data information that it can create asset specific streams as it is possible with PI Interface/Connector for UFL.
  • Kenneth Barber
    Aug 18, 2026
    I have a similar issue. I need to save the contents of an invoice to PI, where there is 1 tag for each type of charge. However, a new type of charge can appear at any time, and the PI Connector For UFL will gladly create a new tag to store this new data. Using auto-select for data discoveries for the AVEVA Adapter For Structured Data Files is not good enough since discoveries are run manually and just once.
