Status Completed
Product PI Connectors
Created on Aug 18, 2022
Support passing dynamic timestamps to REST API URI
In order to retrieve Forecast data from a REST API, I would like to be able to pass timestamps from the Connector dynamically into the URI. For example: ...rest/forecast.wsgi?type=hourly&start=2017-02-15T13%3A44%3A44Z&end=2017-02-30T13%3A44%3A44Z&SID=PDX
    Aug 18, 2022
    This feature is available in current version 1.3.1.135.
    Aug 18, 2022
    In conjunction with this idea (https://feedback.osisoft.com/forums/555139-pi-connectors/suggestions/19211125-connector-ufl-can-read-af-data-structure) I believe the REST Client should be able to pick up any URI parameters from AF Attributes. The datasource should be aligned with a template and makes queries as elements are added (similar to PI integrators but in reverse!)
