Product PI Connectors
Created by Kenneth Barber
Created on Aug 18, 2022
Be able to point the PI Connector for UFL to INI files
Please allow INI files to be pointed to by saving their full path, just like the PI Interface for UFL, rather than saving a copy of an uploaded INI file. This makes editing, testing, debugging, etc. much easier.
    Aug 18, 2022
    The proposed solution in this request is not advisable for security reasons. The current process ensures that the change to the parsing file is accomplished with credentials that allow administration of the connector. The question I have is what is the underlying problem that fostered this solution? If it is something like it is hard to deploy updates to the parsing script (.ini file) and maybe this is especially challenging during development, then that idea would be worth capturing for sure.
  • Gabriel Verreault
    Aug 18, 2022
    Since the connector can be managed remotely (web admin ui), then saving the INI as a path is not ideal in my opinion.
  • Mic Paluszak
    Aug 18, 2022
    From my experience, deploying a UFL Connector solution requires a LOT of edits of the INI file as part of the development/testing/debugging process. After each INI file change, the required procedure is as follows: 1. Click on the Data Source List link. 2. Click on ‘See Configuration’. 3. Click on the ‘Change’ button. 4. Click on the ‘Browse…’ button. 5. Double-click on the INI file. 6. Scroll the page down until the ‘Save’ button is visible (I’m using a 1920 x 1080 monitor). 7. Press the ‘Save’ button. 8. Click on the ‘Overview’ link. 9. Press the ‘Start connector’ button. I think any enhancements to make the above process less tedious would be welcome.
