Product PI Connectors
Created by Alan Izar
Created on Aug 18, 2022
Remove conflict between TAU framework and PIBufSS
We should be able to use buffering on one tag that is fed by the connector, in case there are moments when data has to be primed into it using AFSDK.
    Aug 18, 2022
    This is due to PI Buffer Subsystem locking the PI Point it writes to. Since the application (AF SDK) is to prime the data, you simply need to shutdown that app along with the instance of PIBufSS. This is a known workaround per the following KB article. https://techsupport.osisoft.com/Troubleshooting/KB/KB00093
