Product PI Connectors
Categories General
Created by Gabriel Verreault
Support Failover at the data source level
For PI Connector (1.x) that support failover like OPC UA, failover will only occur when all data sources get into a bad state. Failover should not have to be configure at the PI Connector node level, but for each data source. Use case 1: If 3 connectors are installed: -ConnectorA can connect to OPC1 and OPC2 -ConnectorB can connect to OPC1 and OPC3 -ConnectorC can connect to OPC2 and OPC3 Impossible to configure failover with the current implementation Use case 2: -ConnectorA has 5 data sources and is primary -ConnectorB has 5 data sources and is backup If 4/5 data sources on ConnectorA reach a bad state, failover will not occur Use case 3: -ConnectorA connects to OPC1 and OPC2 -ConnectorB connects only to OPC1 since OPC2's license only supports one connection Not currently possible
    At the current time, we are not planning this functionality. If you have a need for this, kindly upvote this item which will allow us to gauge wider interest and applicability.
  • Gabriel Verreault
    Since this idea was declined, there is no way to upvote it...
