Status Completed
Product PI Connectors
Categories General
Created by Kenneth Barber
Share PI server configuration information across all PI Connectors by default
In most cases, the same PI Data server and the same PI Asset server will be used for all PI Connectors that a customer is using, so it makes sense to propagate the most recently inputted PI server configuration information to all PI Connectors by default. This avoids repetitive configuration. Then the user only needs to configure PI server information if it differs from the default.
    Once the new Connector UI is released, this should address most of the concerns referenced in this idea. The Connector UI will allow you to manage multiple PI Connectors at once and remove most of the duplication per Connector instance.
  • Kenneth Barber
    The PI Data Collection Manager has been released. Please mark this as "Completed".
