Product PI Connectors
Created by Fred_EYRAUD
Give the ability upload different Tag Naming files in DCM / OPC UA Connector
When uploading a "Tag Naming" file in DCM, this file completly replace the existing Tag naming. It mean that a Tag naming file must be done for all datasources within one connector. It would be a lot more easy when dealing with a large number of tags to be able to import a list of new or modified tags. DCM will then compare the imported file with the existing list and make the required modification or creation. An option to delete some datas using a filter will then be usefull.
  • night2day
    Also the risk of changing wrong tags by mistake is lower. This changes should be a minor amount of implementation work.
  • Hobbe
    I think this is an important feature! As it is now, when you just modify or add signal from one source then you are risking changes in all other sources. You should be able to deal with one query at every time if you want.
