Status Completed
Product PI Connectors
Created by Gabriel Verreault
Selecting a subset of items from the same OPC UA template
When multiple OPC objects share the same template, you can only either select the entire template or not since only the template would be populating the filter file. In the example above, if one were to want to bring CC1001 in PI but not CC2001, then, they would need to be moved to a specific folder in the UA Server or change the template on the UA Server side. There should be a user-friendly way to perform more granular selection
    This request has been addressed in PI Connector for OPC UA version 2.0.1.33.
    • Gabriel Verreault
      Reply
      It is now possible to define "IncludeDataTypesInFilter": true, in %PIHOME64%\Connectors\OpcUa\Configuration\Datasource.config.json, then restarting and re-discovering the data source to have separate entries different data types.
