PI Connector for IEC 60870-5-104: to filter IOAs
Considering the following scenario encountered by the customer: In IEC-104 data source, there might be 500 signals of single point (type=1, M_SP_NA_1) and 1000 measurements of normalized value (type=9, M_ME_NA_1); however the customer would not like to transfer all those signals and measurements into PI system with PI Connector for IEC 60870-5-104. How to configure the connector to filter them (such as filter them by IOA of signals and measurements)? Just like what can be done with filter file in PI OPC UA Connector?
    • brijesh gohel
      Reply
      Jul 8, 2024
      As i see in IEC104 Connector, there is no Health status tag like OPC DA, OPC UA.
      Example: Device Status, IORate, etc.
    • brijesh gohel
      Reply
      Jul 8, 2024
      1) I have a multiple make Scada like ABB, Siemens, Bhel make Max DNA and the Protocol is IEC104. As i found that all the data source tag has created in PI system Automatically through the Pi connector for IEC104. I need some specific Tags in PI system.
      Example : ASDU Address is 75. There are 5000 Tags available in SCADA for this Address and I want 1000 Tags for PI system. But the problem is all the Tags created by the connector. Also rebuild PI tag after deletion and no manually creation for the PI tag.
      2) PI tag Naming pattern and PI Points attribute can not change. Due to this unable to make PI AF in Template format. As you know, through templatizing we can consume time and develop systematically. Point source, description also can not change.
      Reply
      I have an use case from a customer that is collecting data from 50+ components using IEC 60870-5-104 protocol but just a small subset of data is needed from each component. Since the connector does not support filtering through IOA address (only ASDU), there is no way to collect this data without relying on another gateway (and therefore another potential point of failure) that could do a protocol change to something we could create only the necessary tags to it, like an interface. I believe being able to filter the amount of data one wants to receive from the connector is really important as it enables more control over the kind of data customer wants to bring in to PI.
