Product PI Connectors
Enable setting tag attributes in MQTT Connector
The MQTT Connector should have ways to set tag attributes. There should be way to set the default compression and exception settings and also other tag attributes like point and data security.
  • Ramit Singh
    Aug 7, 2024
    It would be useful to have the option to manually select whether an attribute (e.g., description) should be synchronized by the connector. My current use case would greatly benefit if I was able to manually set tag descriptors.
