Product PI Connectors
Created by marcogiunti
Apply the Connector Relay to IEC 60870-5-104 Connector
Adding the Relay and the DCM framework to the "legacy"IEC 104 Connector in order to improve the architecture management and security
    At this time, we do not plan to add DCM and Relay compatibility to PI Connector for IEC 60870-5-104.
  • sahilp
    Apart from the potential security benefits mentioned in the original post, I wonder if by including the relay in the 104 data acquisition chain it could be possible to change the tag name of the stream. Right now the tag names are system generated based on the IOA, which most business users don't care about and I don't know how easy it is to build the PI AF structure on top of IOA numbers. Having a neat way to rename the tags would be very useful and if it means that the DCM / Relay combo needs to be included, that is OK.
