Product PI Connectors
Created by rodolforotti
Created on Aug 18, 2022
Remove or disable the PI Connector UFL function which puts "Excluded" into attributes
If the user has two different UFL flows working on same elements and attributes, one flow puts "Excluded" into the attributes created within the second one and vice versa. Giving the possibility to the user to disable this function would be a smart solution. (To give an example: if one UFL flow creates elements and its attributes and another flow creates only EventFrams referenced to those created elements, there are 2 ways: 1) having EventFrames referenced to elements (using "StoreElement" funcion tin the INI file) and all attributes created with the first flow in "Excluded" 2) having EventFrames not referenced to elements and all attributes created with the first flow correctly working)
  • Admin
    Alan Izar
    Jul 18, 2023
    Declined - At the time we will not be implementing this idea since it does not align with our current data collection strategy.
