Product PI Connectors
Created by Hobbe
Created on Aug 18, 2022
Payload configuration
I want to be able to define a POST or PUT payload in the connector. Also the option to import the payload through a file. Add a testing capability so you can see the respons from the POST or PUT command.
  • Hobbe
    Aug 18, 2022
    I use a JSON formatted payload { "code":"request", "cid":4747, "adr":"/getdatamulti", "data":{"datatosend":[ "processdatamaster/temperature", "devicetag/applicationtag", "iolinkmaster/port[1]/mode", "iolinkmaster/port[1]/comspeed", "iolinkmaster/port[1]/pin2in", "iolinkmaster/port[1]/iolinkdevice/vendorid", "iolinkmaster/port[1]/iolinkdevice/deviceid", "iolinkmaster/port[1]/iolinkdevice/applicationspecifictag", "iolinkmaster/port[1]/iolinkdevice/pdin", "iolinkmaster/port[1]/iolinkdevice/status", "iolinkmaster/port[1]/iolinkdevice/productname", "iolinkmaster/port[1]/iolinkdevice/serial", "iolinkmaster/port[2]/mode", "iolinkmaster/port[2]/comspeed", "iolinkmaster/port[2]/pin2in", "iolinkmaster/port[2]/iolinkdevice/vendorid", "iolinkmaster/port[2]/iolinkdevice/deviceid", "iolinkmaster/port[2]/iolinkdevice/applicationspecifictag", "iolinkmaster/port[2]/iolinkdevice/pdin", "iolinkmaster/port[2]/iolinkdevice/status", "iolinkmaster/port[2]/iolinkdevice/productname", "iolinkmaster/port[2]/iolinkdevice/serial" ] } } respons: {"cid":4747,"data":{"processdatamaster/temperature":{"code":200,"data":30},"devicetag/applicationtag":{"code":200,"data":"AL1350"},"iolinkmaster/port[1]/mode":{"code":200,"data":3},"iolinkmaster/port[1]/comspeed":{"code":200,"data":1},"iolinkmaster/port[1]/pin2in":{"code":200,"data":0},"iolinkmaster/port[1]/iolinkdevice/vendorid":{"code":200,"data":310},"iolinkmaster/port[1]/iolinkdevice/deviceid":{"code":200,"data":733},"iolinkmaster/port[1]/iolinkdevice/applicationspecifictag":{"code":200,"data":"***"},"iolinkmaster/port[1]/iolinkdevice/pdin":{"code":200,"data":"00F3FF00"},"iolinkmaster/port[1]/iolinkdevice/status":{"code":200,"data":2},"iolinkmaster/port[1]/iolinkdevice/productname":{"code":200,"data":"TV7105"},"iolinkmaster/port[1]/iolinkdevice/serial":{"code":200,"data":"000079227024"},"iolinkmaster/port[2]/mode":{"code":200,"data":3},"iolinkmaster/port[2]/comspeed":{"code":503},"iolinkmaster/port[2]/pin2in":{"code":200,"data":0},"iolinkmaster/port[2]/iolinkdevice/vendorid":{"code":503},"iolinkmaster/port[2]/iolinkdevice/deviceid":{"code":503},"iolinkmaster/port[2]/iolinkdevice/applicationspecifictag":{"code":503},"iolinkmaster/port[2]/iolinkdevice/pdin":{"code":503},"iolinkmaster/port[2]/iolinkdevice/status":{"code":200,"data":0},"iolinkmaster/port[2]/iolinkdevice/productname":{"code":503},"iolinkmaster/port[2]/iolinkdevice/serial":{"code":503}},"code":200}
