This list is not guaranteed to be correct. Here it goes:
PI Prerequisites Kit → built into install kits
PI Server = PI Data Archive → PI Server = PI Data Archive + PI Asset Framework
Float16 → Float32 & Float64
PI Users & PI Groups → PI Identities
PI Trusts → PI Mappings
PI Firewall → other firewalls
PI Module Database (MDB) → PI Asset Framework (AF)
PI Batch Subsystem → PI Batch Database → event frames (PI AF)
Zero, span, typical value → limit traits (PI AF)
PI AF Collectives → SQL Server AlwaysOn Availability Groups
PI AF models, layers, ports, & connections → (none)
Sigmafine → (none)
PI Advanced Calculation Engine (ACE) → PI Analysis Service
PI Performance Equations → PI Analysis Service
PI Alarm & PI AlarmView → PI Notifications → notification rules
PI Statistical Quality Control (SQC) → notification rules
PIPC logs → PI Message Subsystem (PI SDK message logs) → Event Viewer → log files
PI API → PI SDK → PI AF SDK
About PI-SDK → PI SDK Utility
API Buffer Server (BufServ) → PI Buffer Subsystem (pibufss) → built into PI Connectors, the PI Connector Relay, and AVEVA Adapters
Phase 1 UniInt failover → Phase 2 UniInt failover
PI Interface Status Utility & watchdog points → UniInt health points
PI OPC Tool → PI OPC Client Tool
MCN Health Monitor (PI Performance Monitor interface + PI SNMP interface + PI Ping interface + PI TCP Response interface) → PI Connector for PI System Health? → ???
PI Interface For HTML → PI Interface For UFL → PI Connector for UFL → AVEVA Adapter For Structured Data Files
PI Interface For Flat File Data → PI Interface For UFL → PI Connector for UFL → AVEVA Adapter For Structured Data Files
PI Interface For BACnet → PI Connector For BACnet → AVEVA Adapter For BACnet
PI Interface For Ping → PI Connector For Ping
PI To PI Interface and its APS Connector → PI System Connector 2 (kind of) → PI System Connector 3
PI Interface For DNP 3.0 → AVEVA Adapter For DNP 3
PI Interface For Modbus → AVEVA Adapter For Modbus TCP
PI Interface For RDBMS → AVEVA Adapter For RDBMS
PI Connector for OPC UA → AVEVA Adapter For OPC UA
PI Interfaces → PI Connectors → PI Adapters (renamed to "AVEVA Adapters")
PI AF Builder & PI Tag Configurator & PI Module Database Builder → PI Builder
PI OLEDB Provider → PI OLEDB Enterprise → PI SQL Client
PI Web Services → PI Web API
PI BatchView & PI ProcessBook → PI Coresight & PI Coresight for iOS → PI Vision
PI ActiveView → PI WebParts (formerly RtWebParts) → PI Vision
PI Manual Logger Mobile → PI Manual Logger Web → PI Vision (future?)
Qi → OSIsoft Cloud Services → AVEVA Data Hub → AVEVA CONNECT
PI Cloud Connect → AVEVA CONNECT?
Any OpenVMS PI program (includes PINet) → (nothing)
PI DataSheet Control → ???
PI ProcessPoint → ???
PI ProfileView → ???
PI System Directory → ???
RtBaseline Services → PI Data Services
vCampus → PI Developers Club
PIoneer program → PI Champions → (nothing)
I deleted the contents of this comment because my next comment is a repost of what was in this comment and I didn't notice at the time that I could just edit this comment, but now I can't get rid of this comment because I can't delete my comments.
