Explain the difference between each type of blog post audience
When you write a blog post on the new PI Square, you are presented with these options in the "Audience" dropdown menu:
  • All
  • Authenticated User
  • Community
  • Customer
  • Internal
However, it is not clear what each option means. Please make this clearer. Additionally, they are currently listed in alphabetical order, but they should instead be listed in order of privacy.
    • Christoph Rose
      Reply
      Aug 25, 2022
      Yes this is quite confusing. I published a test blog with the "Internal" audience, which apparently means I can't see my own blog.
      Reply
      Aug 25, 2022
      Hi Kenneth, the documentation for the different audience settings is here: https://pisquare.osisoft.com/s/article/000037992
    • Kenneth Barber
      Reply
      Aug 25, 2022
      Thank you, Alex. This suggestion can be marked as "Completed". What type of user would be considered "Community"? To be clear, I'm asking about the type of user and not the audience type of the same name. In what case might someone want to select the "Guest" or "Community" audience types? For "Guest", it seems strange to lose access to something once you log in or gain access to something once you log out.
