Exclude certain event frames when performing backfilling/recalculation
As an asset-analytics user, I need a way for certain event frames to be excluded when backfilling an analysis . Use case: We have several event frames that are used as Logs/Shift books. Those events do contain a few static attributes. such as comments, quality information, etc. Some also have event frames linked manually (in the form of event. frame references). Our problem is that if we start a backfill/recalc, the manual entries will be deleted and the event frame references will be lost.
    We currently do not have any plans to implement this request. While we understand the specific use case, problems arise when you have a stream of event frames, intermixed with recalculated and un-recalculated event frames. This can lead to intended consequences.
  • MichaelHuber
    But, may you explain me please.. how the AnalysisService KNOWS which eventframes belongs to which analysis? (it is not the primary referenced element and Not the name)
