I've been working with the PI Monitor templates that the PI team created a few years ago. There were some templates that had a standard Status Attribute. In this case, it just covered preventing the generation of Event Frames.
If the Notifications Suppressed attribute = True, then the Event Frame triggers would be set to False.
IF Suppressed=True, then the Event Frame Variable Send_Notifcations = FALSE.
Each Trigger contains "AND Send_Notifcations"
They also added a Analytics that looked at the Parent element for the same Attribute and/or the Operational Status of the Parent. Either could disable the child Elements. If you set your elements up hierarchically, this Status eventually flows down to the bottom elements.
I added a table that can match all the element under a sub-tree. A function allows all the children to set Notifications Suppress = False at the same time. With a time stamp, I can do the same thing that the OSI NOC could do. i.e. quiet alarms until a certain date. This prevents the notification suppression from being forgotten.
