Allow AF Enumeration Set as data type of column in AF Table
As a user, I want to be able to use AF Enumeration Set as a data type in a column of an AF Table, so that I can populate the column based on defined values in an AF Enumeration set.
  • BradR
    Is it possible that there is a work around? If the table column is type Interger, will PI AF recognize the Interger value as a substitute for the enumerated value? Each enumerated value in an enumeration set is assigned a corresponding numeric value. For example, 1 = CAT, 2 = DOG, 3 = BIRD, etc. If the column/row contains a 3, will PI AF recognize that as BIRD if retrieved via table lookup into an attribute defined as an enumeration set?
    You can use a table with a column type of Int32. Add an AF table with 2 columns. Make the second column (ColumnName2) a value type of Int32. Add the following three rows to the AF table: ColumnName1 ColumnName2 str1 0 str2 1 str3 2 Add an AF enumeration set (Enum1) with the following values: {0, CAT}, {1, DOG}, {2, BIRD} Add an element that contains two attributes: Attribute1 and Attribute2. Set Attribute1's value type to Int32. Set Attribute2's value type to the AF enumeration set Enum1. Bind Attribute2 to a table lookup data reference with the following settings string (without the double quotes): "SELECT ColumnName2 FROM Table1 WHERE ColumnName2 = @Attribute1 ORDER BY ColumnName2" As Attribute1 is changed then Attribute2 displays the corresponding table entry that matches ColumnName2's value. This in turn will display the Name that matches the AF enumeration value. Note: make sure to refresh the Attribute2 after making a change to Attribute1.
    BTW, you can easily use ColumnName1 as the table lookup. Add another attribute, Attribute3, which is type of string. Add another attribute, Attribute4, which has a value type of Enum1. Bind Attribute4 to the Table Lookup data reference and set the settings string (without the double quotes): "SELECT ColumnName2 FROM Table1 WHERE ColumnName1 = @Attribute3 ORDER BY ColumnName1" Now change Attribute3 from str1 to str2 to str3, refreshing the attributes after each change. You'll get the results in Attribute4 as CAT, DOG, and BIRD, respectively.
  • Gael
    This could be used in many cases and not only for manual inputs (ex: settings retrieval such as thresholds based on tag status...). This could be only the string value of the enumeration. A feature to have!
  • Gael
    This could be used in many cases (ex: settings retrieval such as thresholds based on tag status...). This could be only the string value of the enumeration. A feature to have! Similar user voice: https://feedback.osisoft.com/forums/555148-pi-server/suggestions/36768184-allow-value-type-enumeration-sets-in-af-tables?_ga=2.106877891.1538329517.1585754786-431683007.1572527714
    We use AF-Tables for some manual data entry. This works pretty fine. In some cases it would make sense to give the user a pre-defined selection of values, so that the data alwas has the same format. So allowing Enumeration Sets in AF-Tables would be great.
