As a notifications admin, I have to move between the management plugin and elements page when I want to edit multiple notifications
With PI Notifications 1.X, a notifications admin, had the ability to use the “Notifications” tab in PSE. Some users would frequently use this tab to run a search on their notifications and return a results set (list of notifications matching their search criteria). Then they would navigate through this list and find the notifications they want to make an edit to. For example, if they wanted to remove a contact from several notifications in this list, they could choose one notification, remove a contact, check-in, select a different notification in the list, remove a contact, check-in, rinse and repeat. With PI Notifications 2.X, to achieve the same function explained above, a notification admin now has to navigate to the “Management” tab in PSE, run a search on their notifications, find a notification they want to make an edit to, select the “Notification rule configuration” button at the bottom which sends them to the “Elements” tab, make the edit, check-in, then navigate back to the “Management” tab, find where they were in their search results, find the next notification they want to edit, select the “Notification rule configuration” button at the bottom which sends them to the “Elements” tab again, rinse and repeat. This process seems much more tedious and time consuming and can be very frustrating.
