Categories Notifications
Notifications for events in the past
Currently notifications are not triggered (send) by events that are more than 72 hours in the past. For me it is necessary to get notifications from events in the (endless) past. Ideally I would like to configure for each notification separately the time range (from now on backwards) in which the notification should be triggered.
  • Yuriy Sadovskiy
    Dec 5, 2024
    Dear Developers,
    It would be great to be able to configure the time range (from now on backwards) in which the notification should be triggered. Even if not for each notification (ideally), but for the whole Notification system. We work a lot with historical data, and I think we are not the only one. It should not be dangerous to give users the possibility to configure that, because there is always default value 72 hours. Could you please check this possibility? Thank you very much!
  • Gregory Malek
    Jan 31, 2024
    It would be very useful to have the option to send out notifications for events more than 3 days old. Occasionally we need to manually correct certain PI data and regenerate a revised version of the original notification.
    It sounds like this may actually be a request about the creation of the Event Frame rather than the sending of the Notification. Or is it both? Also, if historical EFs are getting created, why is the preference to receive an e-mail instead of just using a client tool to look up the history?
    For a lot of TAGs we receive the data very late. For example, somewhen between 1st of May and 1st of June we receive a value for the timestamp 1st of April (this value is valid for the whole April). When the data comes in, I need to be informed that it is available in the PI-System so that we can do our monthly technical account for April. The event frame for this event is getting created, but the notification is not triggered, because the timestamp is too far in the past (>72h).
  • HolgerJoistOmv
    I'd like to have this feature for testing notification mails for situations that rarely occur.
  • Christoph Rose
    We are using Event Frames and the triggered notifications to a web service delivery endpoint in order to run more complex analyses outside of PI and return the results into the PI system. As notifications to the web service are no longer triggered when backfilling more than 72 hours in the past, we will have to create a separate solution for historical analyses and for live analyses. Being able to configure the time range within which the notification would be sent when backfilling would allow us to use a single solution for the running system/live analyses and also historical analyses.
  • LClark
    If you use PI Notifications to send for example daily reports and those reports are missed for more than 3 days, then you effectively have lost the ability to send the reports. You must manually create them using other PI client tools. It seems like when you are manually backfilling analyses that generate the notifications, there should be a simple configuration option to increase/decrease the 72 hour setting or disable it all together.
  • peheuvel
    Because of a serious incident in our DC the notification server was >72 hours not operational. We also would like to have this parameter to be set within a parameter.
