Under the "Event Frame Search" option, give users more options for triggering on Attribute Values
When setting a notification's trigger criteria and specifying the "Event Frame Search" option, give the user more options for triggering on Attribute Values. Current options: Equal, Not Equal Suggestions: Greater Than, Less Than, Greater Than Or Equal, etc. Additionally, allow the user to specify AND/OR clauses between multiple Attribute Value triggering criteria. Currently, this seems to be an implicit AND only.
      Reply
      +1! We typically use the same event frame template for similar events - even if they are of different severity level - so being able to use >, <, etc logical operators would allow us to keep using a smaller set of event frame templates while providing flexibility on which events need to trigger a notification. Further, I can have multiple notification triggers that use the same event frame template but send to different groups based on these logical conditions. With only == and != operators, I am forced to either add several boolean attributes to my event frame as flags for each condition, or create and manage some kind of digital state attribute on the event frame. This feels like more complexity than necessary.
      Reply
      This also applies to adding additional criteria to an SQC-analysis generated notification, since SQC analyses don't allow additional logic in the start triggers.
