Automatic Event Frame Name Reevaluation
I would like to see an option on an event frame generation analysis, probably under advanced event frame settings, that enables automatic event frame name reevaluation at the end time of the generated event frame. Right now I have event frame generation analyses running where I want to use an attribute value as a substitution parameter in the EF name, but the value for that attribute is not retrieved until after the start time of the event frame. Right now I am manually selecting and reevaluating event frame names which isn't sustainable, and I feel that this is a feature that should be available without diving into the AF SDK. My event frames are collecting all the right attribute values, but I need to reevaluate the naming pattern once the event frame has ended. Maybe there could be a post-event time setting for name reevaluation similar to the root cause duration that allows the user to set a wait time for the reevaluation trigger, which would be great if the applicable attribute's retrieval by time is set to at or after the end time.
