114 VOTE
Categories Event Frames (EF)
"Outputs at Start"group
It would be nice if there were an "Output at start" option to output values at the start of an event frame. Currently there is an "Outputs at close" option for Event Frames.
    Apr 6, 2023
    Hello, thank you for your comments on this idea. I understand that we would like to get output values at the beginning of an Event Frame, instead of having to wait until the EF is closed.
    We recommend creating a separate analysis to capture this data, similar to the format: IF (EF_Start_Condition) = "True" THEN (Output_Calculation) ELSE NoOutput(). Can you please share why this is not a suitable method to get these values?
  • Kevin Wood
    Feb 19, 2026
    🤣Can you please share why this is not a suitable method to get these values? 🤣
    I guess Aveva you have to decide if your vision for the product is one where users can do things the obvious and intuitive way, or one where they have to get clever and do things the complicated hacky way.
    So one obvious problem with your method is wanting the output to evaluate exactly once per frame (e.g. for counters). I'm sure there is a way to do it via some arcane combination of attributes and HasValueChanged, but doing things that way is going to involve questions any competent engineer will get spooked by, like "If I have a separate analysis calculate the value using the same criteria as an event frame, and that event frame sends a notification using 'value at start', will the notification send the value from before or after the other analysis updated it?"
    Nov 26, 2025
    The outputs at Close does not meet our business need, because TagVal is only applicable for PI point, but we need to record some average value which is calculated as AF attributes. strong suggest adding Outputs at Start.
    Thanks,
  • Mike Horrocks
    Jan 28, 2025
    It would be useful to be able to output any of the variables defined in an Event Frame to attributes when they are evaluated, in the same way any variables can be output during the evaluation of an "expression" analytic. i.e. when the Even Frame scheduling executes the outputs can be updated.
    The benefits are:
    • increased efficiency - as the variables are already being evaluated adding the option to output them avoids creating additional "expression" analyses that duplicate the expressions, or are created simply as dependencies for Event Frames.
    • more dynamic use of Event Frames for exception based surveillance - if an event frame is active, this can be output to an attribute that can be used for traffic lighting (multi-stating) on PI Vision displays, or rolled up into counters that summarize at a higher level number of active Event Frames.
    • if the EventFrame() function was available to variable evaluation it would also be possible to create updating KPIs as the event is ongoing. For a simple example, TagMax(temperature, EventFrame("StartTime"), '*') would give the maximum temperature reached so far during an active event frame.
  • MattBa
    May 3, 2024
    To answer the admin response above, the simple answer is that not all customers have unlimited PI tags and when applied to several thousand assets, this adds up to be allot of PI tags. Maybe that is AVEVA's goal? Not to mention the extra steps we need to take to create the PI tags and dump data to them. Why not just allow the option to send variables or data at the start of the event, or the end? I can't tell you how much time I’ve spent tinkering with things just to get the data at the start of an event frame.
  • MattBa
    May 3, 2024
    Further after two years, why is the status "NO STATUS?" I really feel like AVEVA has not made many positive changes over the last 3 years. I used to think OSISoft was amazing responding to customers....
  • MattBa
    May 3, 2024
    This has been out here two years! Most people want the data at the start of the event. I think its allot that we have to do all this "Magic" just to get values or valrriables at the start of the event frame. We should be able to return the start or end values. I don't think this is much to ask!
  • leonard
    May 3, 2024
    HI, I would like to capture the real startTime of the Event. In my example, my eventframe is like this: timeEq('tag','*','-10m',"On")> 600. So at Output Start I would setup something like EventFrame("StartTime") + '-10m'. And I am agrre with other comment. Same package, we don't have to create additional anlysis!. You have "Output at close", why you don't develop"Output at Start".
  • zhuhe
    Oct 25, 2023
    Hi admin,
    Requirement:
    PT5550>120bar or PT5551>120bar,and the two pressures keep 2hours , then trigger a event and send an email to the our cutomer.
    we need a future timestamp (the event start time +45h) in the email . This timestamp is cutomer's delivery time. How to do it. Thanks.
    if we have outputs of starts,Maybe the function is simple.
    Sep 14, 2023
    The Archived output timestamp for the event start time that mapped to a PIPOINT data reference attribute Written in the archive at the end of the EF. I need to use this value (the archived Event start time) for another analysis even if the event not ended yet and i can't do this now.
  • Christoph Rose
    Apr 11, 2023
    A limitation with a separate analysis that mirrors the EF Start Condition is that a normal analysis does not have the capability to easily do the "True For X" check that EF analyses provide.
    The other workaround with using the EF start time in the "Output at Close" is also limited as the output timestamp can't be set. So you can write the value of something at the EF start time into a PI Point, but only with the timestamp of the EF end time.
    Capturing values in an event frame also doesn't help, as those values are not easily available in the rest of the PI system.
  • lovetolaugh
    Apr 10, 2023
    The recommendation from the Admin is what we are forced to do now. Would much rather have the data available when the EF starts and ends instead of having to create multiple analysis
  • BradR
    Apr 8, 2023
    Event frames provide a means for "packaging" related data surrounding the event. An example might be calculating TagMax(), TagMin(), TagAvg(), etc. of a group of values just prior to EventFrameStart. Keeping the calculations within the event frame aligns the timestamps based on the event frame. This ensures that the results are sychronized by the event.
  • Justin Jackson
    Apr 6, 2023
    While this would work that fact that have to create additional Analyses is the main drawback. Its nice to have everything packaged up in a single Analysis that is related to what trying to accomplish. If there was an ability to Output at Start, then could calculate value(s) that were involved in triggering the EF and write the results to attributes on the template, all within a single Analysis.
    If could do this on a single Analysis, which is possible with the Output at End function currently available, adding the ability for doing this on Output at Start would increase the usability of this while not creating multiple additional Analyses just to calculate a value (that I am already calculating on a different Analysis).
    Justin Jackson
    Ameren Generation OT Support
    jjackson9@ameren.com
    Help Desk: 314-554-4357
    piregsupport@ameren.com
    Apr 6, 2023
    By this logic, you never would have created functionality for an output at close. From a management and readability standpoint, it makes more sense to have all outputs related to a particular event frame all contained in the same analysis. Cascading analysis are not easy to follow and troubleshoot.
  • zhuhe
    Apr 6, 2023
    Yes, we really need this function.
    Yes! So many use cases to think of. In many cases you want to know something when it started, and at what time, not when it stopped.
    Can you provide some example use cases?
  • lovetolaugh
    I want to write to an output when the Unit comes offline. I also want to write to an output when the Unit comes online. I would like to do that with One event frame generation analysis, instead I have to have two. Offline Status analysis writes to the "lastonlinedate" output at the close of the event frame. The Online Status analysis writes to the "lastofflinedate" output at the close of the event frame.
    You can do that with currently shipping software. Just configure an attribute with a Formula Data Reference and a %StartTime% or %EndTime% substitution parameter. This would not work if you wish to write the start and end time to a PI Point. If I have misinterpreted your needs, please let me know.
    In response to Roger Palmen, "Yes! So many use cases to think of. In m..." In a more general sense i typically breakup logic into two parts: first determining if something is happening, when did it start and stop?, and secondly recoding an EventFrame on that. To determine when something happens i create an analysis and output the results to a PI Point. That allows me to answer questions like: how often did this happen? How long was this the case? What was the last occurrence? Those questions i can't easily answer within PI using EventFrames. The EventFrame i use to do, well, eventframe stuff, and i trigger this on the first PI Point. Having an option to have outputs at start allows to combine this logic into one unit instead of spread over two.   Take a simple batch as an example, i need both a PI Point (when is a batch running) and an EventFrame (batch reporting, visualization) to answer these questions.
  • Load older comments
  • +14
