Status Completed
Categories Event Frames (EF)
Create event frames with minimum, maximum, and standard deviation attributes
If a user has PI points that are calculated with average, maximum, and standard deviation time range method, it would be great if those points can be referenced as attributes in an event frame template. Right now the time context needed to calculate  a minimum, maximum, or standard deviation is not exposed within an event frame. It would be helpful if the time context can be exposed in event frame templates.
    This has been answered in a previous entry.
    The specific use case for this would be to conditionally send a notification based on the summary values (like Ave or Stdev) captured in an event frame for given attributes.
    This capability is in the AF 2018 release if you create your event frames via asset analytics. You simply configure the EF generation analysis with an expression that outputs to a PI Points. You can then configure a notification based on these output PI Points.
