Categories Event Frames (EF)
Created by meierke1
Stop EF after given time
Als a PI admin I want to have the option to stop/end a EF after a given time. This helps to trigger and track onetime events as for example taking a reactor sample.
    Maybe taking this a bit broader. Not only a maximum duration, but we could also want to "split" the EventFrame at specific times. E.g. stop the running EF at midnight, and start a new EF if the trigger conditions are still true. Example use case: split downtime events on shift changes.
  • Srinivas Ettireddi
    In response to Roger Palmen, "Maybe taking this a bit broader. Not onl..." Exactly, we have requirement to stop the EF at midnight and re-open it to calculate the averages appropriately.  Now, we are struggling  create a EF with proper duration because EF being closed and opened at the same time.Working on taking different approach to periodically check and close the EF before midnight.
    In my operations, we want to create an event frame for a deliberately-triggered test that lasts for a prescribed time. We know how long the test takes, so making the event frame last a prescribed time instead of trying to find a combination of variables to use as an approximated ending trigger would be very helpful.
