Status Completed
Categories PI Builder
Allow for a search on any attribute
In PI Builder, when searching for tags, there is a limited number of attributes available. Add the ability to select the attribute of choice, such as ExDesc. When trying to find a PE tag that uses a function in question, being able to select ExDesc is important
    Existing functionality.
      Reply
      When you're searching for PI Points using PI Builder, in the search bar, start typing the PI Point attribute of interest. In your case, start typing - exd... and so on. You will find that we support searching on the extended descriptor with the exdesc: keyword. In order to keep the search dialog box as clean as possible, we do not have a list of all the PI Point attributes in the UI, but once you start typing, the UI leads you to all the search keywords available for searching PI Point attributes.This is all explained in the documentation.
      Reply
      In response to Stephen Kwan, "When you're searching for PI Points usin..." Thank you. Last night, after seeing the items closed, I found the ability to select the attribute via a drop down in the Datalink search and replied as such to the user who was requesting help. I will send this reply to him as well.   Much appreciated.
