Categories PI Builder
Created by Kenneth Barber
Use PI SQL Client for PI Builder data imports
PI Builder has a few problems:
  • It is specific to Excel.
  • It does not store data in tables.
  • Imported data is static and can become outdated easily, which can lead to frequent imports, the need to publish PI Builder edits soon after import, and the reluctance to save the results of a PI Builder import.
These problems would be solved if PI SQL Client could query the same data as PI Builder and if PI Builder used PI SQL Client for data imports. This way, imported data would be stored in a query table. Query tables have all of the benefits of regular tables (data isolation, readable formulas, banded rows, etc.) and are also refreshable. Rather than just being an edit publisher, PI Builder would also act as a query generator, which is easier than trying to modify the sample queries in PI SQL Commander Lite. Lastly, by moving PI Builder's query functionality to PI SQL Client , we reduce the amount of functionality that is specific to PI Builder. This should make it easier to make versions of PI Builder for other spreadsheet programs, such as LibreOffice Calc.
    As the name implies, PI Builder was envisioned to be used for building AF objects. Its chief goal is not for querying data. We would rather not blur the line between a (primarily) configuration tool vs. a data tool (for example, PI DataLink).
  • Kenneth Barber
    This suggestion would solve this one: https://feedback.osisoft.com/forums/555148-pi-server/suggestions/18668149-use-excel-tables-to-contain-pi-builder-data This suggestion is closely related to this one: https://feedback.osisoft.com/forums/555148-pi-server/suggestions/31708795-store-pi-data-archive-information-in-an-sql-server
  • Kenneth Barber
    I don't see what's wrong with blurring the line. Within OSIsoft, there are many cases of products being expanded beyond their original purpose, or being replaced with something more generalized. The best example is probably the entire PI system. PI (Plant Information) began as a way to manage process data, but now OSIsoft encourages customers to connect PI to financial data and record operator logs in PI. Would it have been different if I had suggested replacing PI Builder with a more generalized add-in (PIxel/PIXL?), or if I had suggested a new add-in entirely?
