Better search criteria in Management tab of PI System Explorer
PI System Explorer Management Tab should have better search criteria. For example, select specific elements in which to rerun an Analysis. Maybe use Element = something OR/AND Element = something else. Or search by element path.
  • Joe Staublin
    Oct 19, 2026
    Add support to wildcard analytic names. The current selection is a dropdown of the defined template/analytic. It you have a standard analytic name in multiple Element Templates, the drop down list is very hard to read.
  • rfesler
    Mar 20, 2025
    would really be great to also filter to elements under a root path
  • WCBrad
    Nov 25, 2024
    Agree with this, Searching for analyses is difficult. This would also be really helpful with new build sections of the database. The initial backfill could be done by the entire cluster with the order being automatically determined, as opposed to running manually through each analysis individually.
  • Brent Bregenzer
    It would be helpful to restrict searches to specific branches of the element hierarchy. Now, the search only allows you to search by element name, but not by element path. This is confusing since the Element Name column in the search results shows the full element path. It would helpful to have one of two options: 1. Keep the element name search but expand the search to look at the full element path. This would allow a search like Plant1*Area1* to return all analyses under a given branch. 2. Implement the full element search as as in PSE Elements plugin and other clients. This would allow users to set a root element for the search.
