Status Completed
Trigger an event frame each day on a specific trigger
I would like to trigger an event frame on a PI Point, however, that trigger may last for several days. During that time I would like the event frame to close at midnight and automatically reopen a new event frame for my event driven event frame. Here is an example: Pretend you are measuring the outside air temperature, you want your trigger to trigger when it goes above 50F, chances are your event frame could go on for days before it drops below 50F. Instead of it to go on for days I want a new event frame to create each day while its above 50F and close the previous days event frame.
    Upon further review, please reach out to tech support as we currently support event frames generation with multiple start triggers and I believe this would solve your needs.
    Can you help me understand what you would do with these event frames? This is so I understand your use case.
    In response to Stephen Kwan, "Can you help me understand what you woul..." Dear Stephen, Thank you for reply. Case: We have some status condition which turn to 1 while my start trigger started.My end trigger end on while status = 2.Sometime status 1 to status 2 takes 2 days to turn. Meanwhile we need to calculate duration of each event along with reason for each day.Also each day reason attached with attribute which calculate event frame count on basis upon days for that equipment.  I hope I am able to explain case. Please let me know if any clarification you need.   Regards
    Thank you, this is very helpful.
