Created by Mohammed Al-Shaikh Jafar
Make AFDiag timeout based on AFService.exe.config settings
Make AFDiag timeout parameter based on AFService.exe.config settings instead of being hard coded.
    Can you tell me what you are trying to do with AFDiag with this use case?
  • Marek N
    AFDiag have hardcoded timeout, so remove duplicates using afsiag /fd /dd simply fail on larger databases and the only way is to do a fix directly on SQL table. It would be good if AFdiag can follow settings in AFService.exe.config
