Display AF Database ID in Database Properties
The IDs of databases on the PI Asset Framework Server is only visible using the PI Web API, AF SDK or by making an attribute using a substitution parameter. It'd be far simpler to just have it displayed in Database properties like how the AF Server ID is displayed on the Server properties.
    ID's are not terribly user friendly. Can you tell me what your use case is? What are you doing with the database ID?
    I'm using 3rd party applications that reference the database ID to create their equivalent in the application. To ensure all the items within a AF Database are correct, I'd like to see the database ID in its properties. The Name doesn't help here since the database name can be changed but the ID stays the same so the ID is referenced by the application
