Created by Hobbe
Analyses Rollup should support Range and more functions
I want the Rollup to use the Range or Delta function.
    Hi, we're reviewing this idea and we would like to request more details on the use cases - i.e. what problems are you trying to solve? The previous comment only described how to work around the issue, but not why you need this capability.
    Please give example on how these would be used.
  • Hobbe
    In response to Stephen Kwan, "Please give example on how these would b..." Hi! Now i use the max and min output to calculate the range in a population of tags. With a range function it works direct.   //Magnus     Skickat med BlackBerry Work (www.blackberry.com)
  • Hobbe
    Hi! For example we have a cluster of temperatures on the stator windings, then i want to use a rollup to detect temperature differences. As it is now i need to use max and min and add acalculation to that. Just using a "Range" function it would give me the answer immidiately.
