Confirmation Yes/No Dialogue Box When Deleting an Expression within an Analysis
Please add a Confirmation Dialogue Box e.g. Yes/No when deleting an expression from within an analysis. It is too easy to hit the X and delete an expression accidently.
    If you accidentally hit delete, simply undo checkout and that would bring it back.
    In response to Stephen Kwan, "If you accidentally hit delete, simply u..." Hi Stephen,                        Thanks for your reply. You are quite correct and I have used that feature for this problem.   The issue is I have also accidently deleted an expression without knowing and in the meantime changed other configuration. In this case it is difficult to undo without knowing exactly what has gone on.     A pop-up on initial deletion of an expression would possibly help.     Regards, Glynn.
    OK, understood.
