Sampled Data with Analysis Data Reference
Customer would like to have Sampled Data with Analysis Data Reference (periodic values output) without creating tags as output for the Analysis.
    Like all data references in AF, Analysis Data Reference executes on demand by the client. As such, the idea of a periodic output does not agree with the design as there is no scheduler. Similarly, since the "trigger" is by the client, the idea of triggering inputs doesn't agree with the design. We currently have no plans to change this design.
  • MAl
    Even the ability of selecting a subset of inputs as event-triggered attributes of the Analysis would be useful. Today all inputs participate in triggering the Analysis where the output Attribute is not a PI Point data reference.
  • FranzK
    I agree with MAI, at least there should be the ability to influence what inputs trigger the analysis. In our use case we use an attribute with Point Data Reference. This attribute is showing if we are in a defined process step. if this is the case, we write the value of an attribute with Table Data Reference (linked table, as this value might be changed later) to our output. as the value of the linked table might change, we don't use a point data reference as output. our use case is similar to what you explain in KB01586. There you write "•Their results are not stored, so the result will always use the most up-to-date process data even if the source data is changed later"
