Analysis with conditional timestamp override
Currently it is only possible to specify one timestamp override per analysis.  I would like a way to set a conditional based timestamp override that way the output timestamp could vary based on the result of an analysis.
    We have concerns over this idea as it would be too easy to lose track of the data stream, i.e. it would not be possible to trace back on how/what created the output values. In addition, there would be numerous potential issues with backfill/manual recalculation/auto recalculation, and dependent analyses. As such, we have no plans to implement this idea.
    The use case for the above request would be if you are using a conditional analysis with a TIMEGE expression the output time stamp will be at the end of the time period rather than the beginning. You can use a time stamp override to compensate for this but that would only be necessary in the true condition of the analysis. The goal would be to only have the override for the true condition and no override for the false condition.
