Status Completed
Created by Kenneth Barber
Preview Results should remember the start and end time
As part of debugging, sometimes I use Preview Results (which is available from right-clicking on an analysis), make some changes, and then use Preview Results again. It would be useful if PI System Explorer would remember the start and end times that I most recently entered in Preview Results. Then it can forget them once PI System Explorer is closed.
    This is in PI Server 2017 R2, available now on https://techsupport.osisoft.com/
    Would you want this on a per analysis basis or global?
  • Kenneth Barber
    I think that global should be fine
    This should be Global.. In PSE when you right click an Attribute and then clikc archived values the start and end is what ever you set it to last. The preview of Analytics should be consistent and behave exactly the same.
    In response to Stephen Kwan, "Would you want this on a per analysis ba..." I think Global would be fine.   Cheers,   Ales Soudek  Principal Technical Advisor (w) (281) 920-6186 (m) (713) 409-8163 "It is a capital mistake to theorise before one has data" - Sherlock Holmes "Do or do not, there is no try." - Yoda "De omnibus dubitandum." - Rene Descartes "It is easier to disintegrate an atom than a preconceived idea." - Albert Einstein "What gets measured, gets done." - W.E. Deming
    This is available with the 2017 R2 release.
