The AF dependency for PI Web API warrants serious reconsideration from an architectural standpoint. Requiring a full AF Server and an associated SQL Server instance solely to support PI Web API configuration introduces a heavyweight, stateful infrastructure component into what should be a lightweight, stateless REST interface.
The dependency also complicates edge and hybrid deployments. PI Adapters rely on the PI Web API to communicate back to the PI system. However, the requirement to maintain AF + SQL as a prerequisite means that even minimal edge deployments must maintain connectivity to centralized, stateful infrastructure. This is fundamentally misaligned with edge computing principles, where services must be deployable in isolated, resource‑constrained, or intermittently connected environments.
The AF requirement introduces:
Unnecessary statefulness into a service that should be stateless
Tight coupling between PI Web API and AF schema/SQL persistence layers
Increased operational complexity, including patching, backups, failover, and lifecycle management of SQL + AF
Higher infrastructure cost, even for small‑scale or read‑only PI Web API use cases
A flat‑file configuration store, embedded database, or pluggable configuration provider would eliminate these constraints and align PI Web API with modern edge‑native design patterns.
