AF SDK Calls using the AFValues.GetValues should include an index of result events, this is to allow direct location of replacement events
The PIPoint.ReplaceValues method requires a replacement of every event in the timerange, however it also may reorder or miss events with the same time stamp. The issue is that if the client wants to replace only a certain event, but must find that event - the replacement is for all the events at that timestamp and the method doesn't seem to allow for precise replacement of a value. The use case is programmatic correction of operator manual entry error, where multiple events have the same timestamp.
    Aug 23, 2022
    Apologies as I meant to set this item to declined with my previous update. Thank you for your valuable feedback. We have no plans to work on this feature in the near future, so I am setting the status to declined. I will update the status if we eventually schedule this work.
