Expose Event Frame Extended Properties in PI SQL Framework
As a PI SQL Framework end user, I need to be able to distinguish between event frames generated by PI Batch Interfaces from different sites or data sources by filtering my query on the name of an event frame extended property. PI Batch Interfaces store the unique ID of the data source as the name of an extended property in the event frames they generate. When multiple PI Batch Interfaces write to the same AF Database, the extended property name can be used to distinguish between event frames from different data sources or sites.
