Categories General
Created by taterhead247
Created on Aug 23, 2022
Import-AFXml (PowerShell) should have ContinueOnError option
Both AFImport.exe and ImportXml (AFSDK) have options to continue on error (like is something is checked out or if there is a duplicate element name). For some reason the PowerShell version doesn't. This should be added.
    Aug 23, 2022
    There is a common powershell parameter called ErrorAction. Unfortunately setting this to SilentlyContinue, Continue or Ignore results in the import stopping and a check-in of some new objects and other objects are left in a checked out state. If ErrorAction is not defined, the import stops and does an undo check-in. Perhaps this common parameter could be implemented properly to solve this request. As a workaround, I'm using the powershell cmdlet start-process to start the afimport.exe.
  • Brent Bregenzer
    Aug 23, 2022
    You can also load AF SDK directly into PowerShell and use the export method. For examples, see: https://pisquare.osisoft.com/s/Blog-Detail/a8r1I000000GvdCQAS/improving-af-backups And https://pisquare.osisoft.com/s/Blog-Detail/a8r1I000000GvEwQAK/exporting-af-databases-using-powershell
